I am using IV 2010. I have one part constrined to move at a distance when I drive the constraint it works fine. Now I would like to constrain a second so when I drive the first part the second moves in the opposite direction the same distance. Thanks,
I am missing something. I constrained it like you said. However when I go to drive the first part second part still does not move. I would like both parts to move at the same time, opposite direction, equal distance. Similar to if you had two objects on a pulley. Thanks.
Attach your assembly here.
