Inventor Forum
need help with F.G
13 REPLIES 13
Message 1 of 14
787 Views, 13 Replies
need help with F.G
Can the Ball part be added between the 50mm Round Rails from the photo of a staircase usingthe F.G?
I know how to add the posts but not the Ball section..there is a ball at every intersection including the end posts
Is it best to split the sketch so as to make editing of the rails easier between the upright posts/balls?
regards
TB
13 REPLIES 13
Message 2 of 14
brendan.henderson
I don't think you can do that with FG members.
FYI, we created separate files fo each bought staunchion type. As we don't manufacture them they are just an inserted part from a library. With a bit of effort they probably could be made into an iPart.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 3 of 14
Thank you
I guess if the Ball feature is not available i could still use the F.G.....would have been good to create this in the F.G though
Could it be made using solid modelling tools and then assembled in an assembly file
Brst Regards
Tony
Message 4 of 14
You can certainly make the frame using the frame generator, you'll just have to add the ball part separately. Once the frame is done, you can treat it just like any other component in an assembly.
Message 5 of 14
I can create the frame in the F.G that is no problem.
How do you recommend i add the Balls to the Frame....do i place the Frame created in the F.G into another assembly and then create the Balls or is there other ways?
How do i then Notch the Frame and Balls so there is no interference?
Any other thoughts appreciated
Tony
Message 6 of 14
The frame you generated is itself an assembly.  You can either add components directly to that assembly or use the frame as a subassembly and place it into another assembly.  It's your choice, depending on how you want to organize your files.
As for the ball, I'm not entirely sure how the frame is constructed.  You could make the ball part like I have it modelled here.  You could even link parameters from the frame's sketch to the ball to have it automatically update the angles and such.
Message 7 of 14
BeKirra
"How do you recommend i add the Balls to the Frame....do i place the Frame created in the F.G into another assembly and then create the Balls or is there other ways?
How do i then Notch the Frame and Balls so there is no interference?"
As I understand, you are creating handrail models and usually the stanchions meets the industry standard (ie. ball size, rail sizes, rail spacing and stanchion's height).
Brendan Henderson's suggestion is right - make stanchions as separate parts as your libray items.
And create the ball as the way it is fabricated and finally you can set the weight of the stanchion in the part file.
We have done this - works perfect from project to project.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 8 of 14
Thanks a lot
If possible would you have an example...have not done before
Thanks for all help
Tony
Message 9 of 14
BeKirra
Sorry I can't give you the model we use as the company's policy.
However, I upload a sketch model and hopefully it can give you some ideas.
BTW, it is a R2014 model.
X² + Y² = C²
Message 10 of 14
in reply to: BeKirra
Thank you
Just to clarify do you then just place these in an assembly file?
Can the frame still be made using F.G and then you insert these stanchions into the assembly?
or
do you create the frame with F.G and then insert the F.G model as a sub-assembly and then insert the stanchions
or
do you create an assembly file and insert the stanchions and separate handrails (.ipt ) without using F.G
Thanks for your help
Message 11 of 14
BeKirra
For handrail models we usually don't use FG.
And yes we insert the stanchions and handrails in an iam file - we normally don't involve large scale handrail models.
HTH.
X² + Y² = C²
Message 12 of 14
Thank you
Message 13 of 14
Just a thought... that's quite a bit like a Tube & Pipe assembly, isn't it?
Message 14 of 14
What is your thoughts on if i create the frame (to hold both steps and stanchions) using the F.G and then insert the Frame created by F.G into another assembly and add the stanchions to this assembly.Could i also then add rails between the stanchions using F.G
