Inventor Forum
need help modeling a fly wheel
5 REPLIES 5
580 Views, 5 Replies
I am new to Autodesk inventor. Can someone please help me in making different radii of highlighted portion, Thank you.Untitled.jpg
5 REPLIES 5
CelticDesignServices
bzia,
I'm assuming you mean the "R7" and the "R12" radii for that cutout?
Simply select the Fillet command and input the first size, select the edges, then select the "click to add" text in the menu and input the other radius size and then select those edges, hit Apply when done.
Jim
Celtic Design Services, LLC
Inventor/AutoCAD/Vault WorkGroups
Always for hire - celticdesign01ATyahooDOTcom
https://www.facebook.com/pages/Celtic-Design-Services-LLC/184666001666426
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Go raibh maith agat (in other words...Thank you!)
udayag
Here's an attmpt. The file was created in Inventor 2012. Please move the End of Part marker down, if necessary.
Udaya Gunasena
Fusion Development
Curtis_Waguespack
Hi bzia,
Here are a few hints on starting this part. Remember to keep your sketches simple.
http://inventortrenches.blogspot.com/2011/03/inventor-101-simple-fully-constrained.html
I hope this helps.
Curtis
http://inventortrenches.blogspot.com/2011/03/modeling-practice-drawings-for-inventor.html
and now apply fillet features ... then pattern the cut and fillets
in reply to: udayag
Thanks, but your file is not opening. I am getting the following error:
   Error in reading RSe stream
in reply to: Curtis_Waguespack
Thank you, your solution was very helpful.
