im trying to extrude a 2d sketch to a 3d object and when i go to extrude it does let me i konw what im doing wrong but i have no idea how to fix it heres what im doing wrong at the bottoms of my sketch 2 splines meet up im trying to connnect the 2 splines with a line but it doesnt let me exatly connect the spline ends toghter i just get close im trying to extrude the figure as a solid but as i said before the 2 ends of my sketch wont connect any help?
heres my sketch
they are all in 1 sketch just multible lines and i need help connecting those lines so i can extrude as a 3d object
You have 4 sketches in the browser. You need to have all this in one sketch in order to extrude a solid.
In order to extrude a sketch as a solid, it has to have a closed loop. You have 4 separate sketches you are trying to connect. Even if you do get all the curves connected, it will not extrude as a solid.
Have you done any of the sketching or part tutorials?
ive attemted the tutorials but im a learn on my own kind of guy but ill look into the tutorilas again thanks
You might start here.
You missed using obvious symmetry about the origin.
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Hay i took another look at the extrution that you made and it wasnt exatly even so i went back to 2d sketch and found that the head set was a little different than the sketch it was uneven and off set
