Inventor General
Member
Message 1 of 9 (1,123 Views)
need help extruding 2d sketch as a solid object?!?
1123 Views, 8 Replies
10-22-2012 05:12 AM
im trying to extrude a 2d sketch to a 3d object and when i go to extrude it does let me i konw what im doing wrong but i have no idea how to fix it heres what im doing wrong at the bottoms of my sketch 2 splines meet up im trying to connnect the 2 splines with a line but it doesnt let me exatly connect the spline ends  toghter i just get close im trying to extrude the figure as a solid but as i said before the 2 ends of my sketch wont connect any help?
heres my sketch
Distinguished Mentor
Message 2 of 9 (1,119 Views)
Re: need help extruding 2d sketch as a solid object?!?
10-22-2012 05:22 AM in reply to: richfazio
You need to put all the sketches together in one sketch.
John Retzlaff
Member
Message 3 of 9 (1,108 Views)
10-22-2012 05:44 AM in reply to: john.retzlaff
they are all in 1 sketch just multible lines and i need help connecting those lines so i can extrude as a 3d object
Message 4 of 9 (1,097 Views)
10-22-2012 05:52 AM in reply to: richfazio
You have 4 sketches in the browser.  You need to have all this in one sketch in order to extrude a solid.
John Retzlaff
Member
Message 5 of 9 (1,091 Views)
10-22-2012 05:56 AM in reply to: john.retzlaff
hay thanks,
              But i still dont understand what you mean by that
Message 6 of 9 (1,088 Views)
10-22-2012 06:00 AM in reply to: richfazio
In order to extrude a sketch as a solid, it has to have a closed loop.  You have 4 separate sketches you are trying to connect.  Even if you do get all the curves connected, it will not extrude as a solid.
Have you done any of the sketching or part tutorials?
John Retzlaff
Member
Message 7 of 9 (1,047 Views)
10-22-2012 04:19 PM in reply to: john.retzlaff
ive attemted the tutorials but im a learn on my own kind of guy but ill look into the tutorilas again thanks
*Expert Elite*
Message 8 of 9 (1,045 Views)
10-22-2012 04:21 PM in reply to: richfazio
You might start here.
You missed using obvious symmetry about the origin.
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Member
Message 9 of 9 (1,042 Views)
10-22-2012 04:31 PM in reply to: JDMather
Hay i took another look at the extrution that you made and it wasnt exatly even so i went back to 2d sketch and found that the head set was a little different than the sketch it was uneven and off set
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
