Dim doc as DrawingDocument,
when Iam using the above code,Error will displayed in DrawingDocument...
Is any namespace for that?
How can i clear it?
First thing: Remove the , after Dim doc as DrawingDocument, <-----
And some more info would be nice. What are you trying to do. Do you use the VBA-editor or iLogic or external VB.net.
Probably in your other post there is the same ,,,,,,,, problem.
Rob.
I want to get sheet number from autocad electrical .Iam using vb.net.
Please help me how to get sheet number from drawing properties in autocad electrical using vb.net.
I need to create a tool,so i want that..
I think you'll get a lot more help in the Inventor Customization Forum.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
