A general question: When place a pump/motor in assemblies do you build you motors/pumps with solid parts.Do you include all the internals parts or model it as a solid or solid parts and then assemble the motor/pump?
Thank you
RH
You can consider a part as an indivisible component in your project, or that can be consider unique in your BOM.
Then you can have subassemblies that contains parts or other subassemblies.
You can consider a subassembly as a group of parts/subassemblies that have a conceptual meaning being togheter.
Then you can have difefrent modeling strategies (from the bottom to the up, or from the top to the down😞
-modeling every single parts and then assemble them
-or you can model the "container", for example a pump, and then fill it with other parts. using multibody too, for example
-mix startegies
Choosing the right strategy depends on your design
Admaiora
Typically one would only include what they need.. If you aren't the pump manufacturer then I see no point in including internals,etc.. just what your company needs.. example.. just the output/input flanges/pump body so you can get the mating and check for any clearance issues.
If I was modeling it up from a drawing I would only do a single part file for it and not take the time to make an assembly unless I really needed it for some other reason.
I have to agree with mcgyvr on this one. Only model as much as you need, ie. the outside profile so you can determine that you have the needed fit and clearance around the motor. We would typically model a motor as a single piece using a CAD file or dimensional data from the supplier or using physical dimensions taken from an actual part.
One thing to keep in mind is that your single piece model may be significantly heavier than the actual part. You can compensate for that by adjusting the material properties or modeling an internal void into the model to obtain the proper weight.
This.
One caution, though - if you just adjust the material properties to get the right weight output, you may wind up with your CG in the wrong place. This may or may not be an issue for you. If you're designing a stationary land-based object, probably not a problem. If you're designing something that goes on a boat or an airplane ... then you likely have a problem.
Rusty
