Using Inventor 2010
I just upgraded from Windows XP to Windows 7.
Not the ipt, idw, and iam file icons are difficult to distinguish between when your in a hurry.
There used to be more contrast and color between the different file types
Is there a setting for this somewhere in Inventor or Windows for this?
This is how they look below.
is that screen shot from an Inventor window or windows explorer, as mine look nothing like that and any option I try does not give me that look. maent the OP's screen shot, but maybe because I am using 2011.
my assembly and part icons:
Try switching to small icons or medium icons dech99. To do that open a window and right click a blank area inside and choose view.
yah, now that I think about it 2010 icons displayed that way. You can right-click inside the directory window, choose view, then try the different options till you find one you like. or use the highlighted slider. Medium or large icons will more than likely give you a preview of the contents.
I have tried the detail setting but they still look like that shown below.
I would like to get them to what they used to be shown below.
Edit:
Nevermind. From your last post, It looks like you did this already.
Hi desch99,
It might also help to turn on the file extensions. Windows 7 is better about renaming, etc. with file extensions on than XP was:
http://support.microsoft.com/kb/865219
I hope this helps.
Curtis
IIRC, they changed them to those for a release and then changed them to the high contrast ones after much user complaining. I can't remember exactly when, but I suspect it was from 2010 to 2011.
I don't think you can desch, i think they went to that type of icon for 2010 and then switched back in 2011 after as cmc noted a lot of complaining. Thin you are stuck with them until you upgrade to 2011 or later. let me look into it as we can always see about replacing them with custom icons.
With a little effort and a free program you can indeed change your icons. Doesn't look too complicated.
http://www.howtogeek.com/howto/12383/change-a-file-types-icon-in-windows-7/
http://www.softpedia.com/get/System/File-Management/File-Type-Manager.shtml
