Extrude the cross section a very small amount (0.001") Take the mass moment
of inertia (from the properties) and dive this by the density then divide by
the thickness you extruded. This will give you the area moment of inertia.
I/rho/l = (lbs-in^2) / (lb/in^3) / (in) = in^4
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Matt-Dimon" wrote in message
news:f14821a.-1@WebX.maYIadrTaRb...
> I am trying to calculate the moments of inertia on the face of a part is
there any way this can be achived in inventor in cm4?
