Welcome David.
What kinds of properties are you trying to match, and in what type of file? Are you talking about parts, assemblies or drawings? There is no match properties tool, per se, like the one in Autocad... but depending on what you are trying to do,... there is probably a solution.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
as indicated - you will need to explain what environment you are working in and what it is you are trying to do.
(see attached)
The CADWhisperer YouTube Channel
The option of matching properties inventor drawings, only meeting for dimensions, but missing the important option of matching properties the hatch patterns.
When you have a section of several parts is very slow to change the angle, scale, pattern shading. It must be done one by one
You can predefine those hatch styles for specific materials to make your life a little easier.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
That's not the issue.
Attached example of the problem.
To get the result of the second image to be modified one by one the properties of hatch patterns, angle, scale and type of pattern.
I see what you mean. I would recommend you add this to the IdeaStation to get traction for it to be added to Inventor.
