How can I make groups for similar components of assembly such as picture below?
thanks
Solved by mdavis22569. Go to Solution.
Solved by wwoehlke. Go to Solution.
I'm not sure what you mean by group ....
However you can do a few things ...
1) a folder ..you pick everything you want and you RMB in the browser and pick the folder option..and it'll move everything picked into it. Or you can drag them in. It will keep all of the constraints...
2) Make a sub assembly IAM from the main Assembly. You can pick everything and go to the Browser again and RMB pick Demote
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
<<<<<< didn't read the date ...just was answering ...now that's funny! I'm actually laughing with a bit of a red face ...
@-niels- wrote:
Not to offend, but both you and ed.mccracken are giving answers that were already given to a topic from 2013...
which the OP already picked an answer for...
... although Michael's answer was more complete, giving two options, and for option 2, giving a much better procedure than the original answer. Might even want to mention that demoting into a subassembly keeps most or all of the constraints.
I'd say one of the EEs ought to mark Michael's answer as a solution.
Sam B
Inventor Professional 2015 SP1 Update 3
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
Sam B
I'll agree on that, so marked as second solution.
It was just the resurrection of an old(er) topic with solution that i found a bit unnecessary.
Niels van der Veer
The Netherlands
