Hi, does anyone could give me some suggestions on how to make the 2D barcode Data Matrix barcode in Photoshop CS4?
Solved by mcgyvr. Go to Solution.
A barcode font may help you. Once you installed it in your PC, any application using fonts can generate barcodes as a font.
Do you need a bar code for the IDW? If so I have one I made years ago I will see if I can locate it if you like...
http://www.lmgtfy.com/?q=photoshop+cs4+2d+barcode
I tried linear barcode in Photoshop CS6. It works well until now. I am using linear barcode font. You may search a 2D one.
Data Matrix has a little more complex algorithem than linear barcode. So it is difficult to draw it manually. A better way is to use a font to create it in your application. This Data Matrix font shows a details
Hello, I have seen the barcode font you recommended, but it is chargeable. Is there any free version for me to use? I don`t want to buy one.
font is one way to go, i think Data Matrix barcode plugin can help you generate barcodes in various image formtas. also it rotate, resize data mode and so on. here is a free trial i foud, why don't you give a try.
@Anonymous wrote:Hi, does anyone could give me some suggestions on how to make the 2D barcode Data Matrix barcode in Photoshop CS4?
go to google for a guide to generate data matrix
