Inventor General
Valued Contributor
Beauand
Message 1 of 2 (189 Views)
make a coil bend instead of straight
189 Views, 1 Replies
09-08-2011 06:55 AM
I have been trying to bend a coil into a circle but i have no answer.  I made the coil fine and i have posted on here for help but no luck.  I was wondering if anybody else had any ideas?
*Expert Elite*
Message 2 of 2 (179 Views)
Re: make a coil bend instead of straight
09-08-2011 10:22 AM in reply to: Beauand
Here's another example where I actually used the bend command on a coil.  Like I mentioned before, it yields an object that has an inconsistent cross-section.  There is also an issue with bending it in a complete circle (360 degrees).
I believe the file is 2010 format.  Drag the End of Part marker down below all features to see how I created this part.
-cwhetten
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
