I have been trying to bend a coil into a circle but i have no answer. I made the coil fine and i have posted on here for help but no luck. I was wondering if anybody else had any ideas?
Here's another example where I actually used the bend command on a coil. Like I mentioned before, it yields an object that has an inconsistent cross-section. There is also an issue with bending it in a complete circle (360 degrees).
I believe the file is 2010 format. Drag the End of Part marker down below all features to see how I created this part.
-cwhetten
