Inventor Forum
lofting around a coiled path
13 REPLIES 13
Message 1 of 14
StrangersDMAX
999 Views, 13 Replies
what would be the procedure for creating a loft around a coiled path? is there a way to make the coil command create a path.
inventor 2014
Windows 7 Pro 64
i7-3820 3.6GHz
32 GB RAM
2 TB HD
NVIDIA GeForce GTX 660 Ti
Liquid Cooled
3D Connexion
CM Storm
twin ASUS LED
13 REPLIES 13
Message 2 of 14
JDMather
in reply to: StrangersDMAX
Coil line as surface body to generate the Path.
Create profile(s) to Loft or Sweep.
Attach your file here if you can't figure it out.
Message 3 of 14
StrangersDMAX
in reply to: JDMather
Im not sure how to upload the file but I hope
this helps. The goal is a simple style turbo compressor housing just for
personal learning of new techniques. I need it to loft from the big circle to
the small one in a coiled path
inventor 2014
Windows 7 Pro 64
i7-3820 3.6GHz
32 GB RAM
2 TB HD
Liquid Cooled
3D Connexion
CM Storm
twin ASUS LED
Message 4 of 14
JDMather
I read you mind and attached the solution to my original post - simply edit the dimensions and you are done.
Message 5 of 14
StrangersDMAX
thanks for the help, just one thing tho, id really like to know what steps u took to get it. in case i want to do it again in the future. im a new to alot of the non basic features. i have a txt book but it just teches basics
inventor 2014
Windows 7 Pro 64
i7-3820 3.6GHz
32 GB RAM
2 TB HD
Liquid Cooled
3D Connexion
CM Storm
twin ASUS LED
Message 6 of 14
JDMather
@StrangersDMAX wrote:
.. id really like to know what steps u took to get it. in case i want to do it again in the future. ....
Well then you are really in luck with Inventor - because it recorded everything I did in the order in which I did it.
Drag the red End of Part marker to just below Coil 1.
Right click on the Coil1 feature and select Visible.
Click on the plus symbol(+) and expand the feature.
Right click on the Sketch1 and examine.
Finish sketch, pull down the EOP to the next step and repeat....
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Message 7 of 14
StrangersDMAX
ok i figured it out thanks very much!
inventor 2014
Windows 7 Pro 64
i7-3820 3.6GHz
32 GB RAM
2 TB HD
Liquid Cooled
3D Connexion
CM Storm
twin ASUS LED
Message 8 of 14
StrangersDMAX
How would make a base for that kind of shape to sit on? If I could just extrude a circle up to and CUT where they meet out and keep the rest would be nice but I caint find that option, only KEEP where they meet. Im sorry for it being a confusing question.
inventor 2014
Windows 7 Pro 64
i7-3820 3.6GHz
32 GB RAM
2 TB HD
Liquid Cooled
3D Connexion
CM Storm
twin ASUS LED
Message 9 of 14
StrangersDMAX
how would u got about making a base for it? i made i hollow with shell but if i just extrude a circle up to it it goes inside of it. is there a way to extrude up to it and everywhere they touch it cuts and leaves the rest? that way it doesnt go inside of it.
inventor 2014
Windows 7 Pro 64
i7-3820 3.6GHz
32 GB RAM
2 TB HD
Liquid Cooled
3D Connexion
CM Storm
twin ASUS LED
Message 10 of 14
JDMather
There are three options in Extrude, Join, Cut and Intersect.
Message 11 of 14
StrangersDMAX
i need to cut where they intersect, but when i put it in it keeps where they intersect.
inventor 2014
Windows 7 Pro 64
i7-3820 3.6GHz
32 GB RAM
2 TB HD
Liquid Cooled
3D Connexion
CM Storm
twin ASUS LED
Message 12 of 14
JDMather
Attach your file here - I can't work from words.
Message 13 of 14
StrangersDMAX
inventor 2014
Windows 7 Pro 64
i7-3820 3.6GHz
32 GB RAM
2 TB HD
Liquid Cooled
3D Connexion
CM Storm
twin ASUS LED
Message 14 of 14
JDMather
I recommend putting this one aside for a couple of days and take the time to go through these
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
also Rob Cohee YouTube Inventor
and http://au.autodesk.com
and older AU at http://www.augi.com
There are also several former examples here very much like yours, but I have no idea what terms to search to find the previous threads.
