Inventor Forum
local light in sub assembly
9 REPLIES 9
Message 1 of 10
1462 Views, 9 Replies
can anyone help me figure out how to embed a light with a part so that it moves with the part when you animate a component such as a car head light moving with the car?
it seems simple but Ive looked eveywhere for the solution.
Do i just animate the light to travel with the component?
also I have multiply lights(street lights) so it would be nice if I can copy the assembly with the light
9 REPLIES 9
Message 2 of 10
mflayler2
From Help section:
Component level
Add a local light to a component to have a light that travels with the component when it is animated. The light parameters are static in this case, that is, whatever the parameters are set to remains the condition throughout the animation. Local light parameters cannot be animated when the light is lower than the top level of the model hierarchy.
Local lights can be the only object in a component model. You can create a model, exit the sketch, add a local light and position the light relative to the model origin work features. You can position a light within the assembly relative to other components or work features. The component position can then be animated using either Animate Component or Animate Constraints.
For BOM purposes, this component should be set as a Reference component.
Assembly top level
Adding a local light to the top level of the assembly allows certain light parameters to be animated. The light is not associated with a part in this case.
Are you having trouble applying the light or seeing it travel in the animation?
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 3 of 10
in reply to: mflayler2
I read that many times in the past week, it still doesnt explain how to embed the light to the object
everytime i add a local light its fixed in the space the probelm i see is that lights can only be added in studio in the [arent assembly.
Message 4 of 10
mflayler2
They should be able to move with the component at the lower level, but you cannot directly animate them at the lower level when in a higher level assembly.  (if memory serves me)
Edit: I just verified this with one of my datasets.  I place a light in a lower component and the state of the light in the lower level is carried through to the the top and will animate with the component, but cannot change the state of the light at the top level.
If you need to change the state of the light while animating (on/off, color, initial position) , then you will have to turn it off in the lower component and use a light in the highest level assembly and use Animate Light to sync with your component.
Message 5 of 10
mflayler2
Gage light in video and attached with new blue light in the gage lens.
http://www.youtube.com/watch?v=oXZl0OQ9sE8
Download files: (will clear 5 days after this post) : http://dl.dropbox.com/u/4015397/Animate%20Lights.zip
Message 6 of 10
thanks! ill try that
Message 7 of 10
Dear Colleagues,
I want to animate a welding process (Autodesk Inventor 2013) with addition a local light, like this.
I tried several times, but I do not know, that how can I assign this local light to the moving "welder tip" component?
(My attempt in attachment)
Thank you for your help in advance,
George
Message 8 of 10
Message 9 of 10
skylinejeff
Mark_Flayler wrote:
From Help section:
Component level
I don't understand the "Local lights can be the only object in a component model".  I'm trying to create a "sign" that has some LED fixtures, and I need to pattern the LED fixtures and have the lights go with them.  I can't create >100 local lights in the top assembly.
So I opened the LED fixture assembly (it has a polycarbonate lens, a backing board, and three small cylinders that represent the physical led bulbs), created a component within the assembly called "light.ipt" and set is as reference.  So now my assembly has four components.
I open the "light.ipt" for edit, without creating any geometry, and start the Inventor studio environment.  Upon trying to add a lcoal light, I get the error message "This command requires model geometry"
So it appears that the local light cannot be the only object in the component "light.ipt" as your post seems to suggest.  What am I missing?
Jeff
Message 10 of 10
in reply to: skylinejeff
can you make a tutorial video about that ?
i'm a sefl-study student and i'm was wondering about this for months
thanks
