I have attached a part that I'm doing for one of our customers.
I am needing to find out what the total length of the cut would be on the end.
We'll be cutting this on our tube laser, and I need the length.
I have used the "measure", but it only gives me one line at a time.
Is there a way to like hold down the ctrl button and pick my lines and radii?
Thank you very much for your help.
Solved by JDMather. Go to Solution.
Oops...forgot the attachment
I think what you want is
3D sketch
Include geometry and click the boundary edges.
Measure > Loop
Thank you.
I'm not too sure what you are meaning, but I'll play around
and see if I can figure it out.
Thank you very much! That is exactly what I need.
