Inventor Forum
letters in text are invisible
8 REPLIES 8
Message 1 of 9
346 Views, 8 Replies
I had this problem in inventor pro 10 and 11...
every time I try to type a text in a drawing or to make (emboss), the text I typed just dissapear after I press Ok!!!!!
even when I reinstall the program there`s the same problem....
What is the cause of this? How can the prog work correctly?
thnx in advance
8 REPLIES 8
Message 2 of 9
JDMather
Search Google on Autodesk Inventor text hotfix.
Message 3 of 9
dijon45
You have to go to Add/Remove programs, make sure that the show update box is check of at the top and look for Windows Update Hotfix KB918118. Remove that and you'll be all set.
Message 4 of 9
JDMather
Why would you do that instead of fixing the problem?
Message 5 of 9
dijon45
Well do you know of a way to fix it?? cuz thats the only way that i know that fixes it for me. Had no problems since then.
Message 6 of 9
Autodesk released a hotfix that resolved the issue with Windows Update
Hotfix KB918118.
T. Ham
CAD Automation & Systems Administrator
CDS Engineering BV
HP xw4300 Workstation
Dual Pentium XEON 3.6 Ghz
4 GB SDRAM
NVIDIA QUADRO FX 3450/4000 SDI (Driver = 6.14.10.9185)
250 GB SEAGATE SATA Hard Disc
3Com Gigabit NIC
Windows XP Professional SP2
Autodesk Inventor Series 10 SP3a
Autodesk Inventor Suite 2008 SP1
Message 7 of 9
JDMather
As I wrote in the first reply to this thread I would go to Google and search on the suggested terms (or search this forum).
The search should turn up this fix from Autodesk.
In addition it might be a good time to update all Service Packs.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9229921&linkID=9242019
You must have turned off Windows Automatic Updates as well or the problem will return on you machine. The Autodesk Hotfix takes care of the problem.
Message 8 of 9
dijon45
Yeah. By following the steps that I listed before. Then the problem is fixed. I got this solution from a previous post on here.
Message 9 of 9
thnx JD Mather...
there`s an autodesk hotfix for this prob but you must have inventor with SP1,2....
thnx again
