I have often problem with drawing view labels. When model is changed and I switch to the drawing then the label is moved to an random position. There is possible to little move with view, or edit label text or switch off/on label and label move back to correct position. This is very unpleasant when there s more views in drawing, is necessary to correct each label.
This happen in Inv2013 and also in Inv2014.
Is not there an possibity to minimize this?
Enclosed is example video.
Thank you
RMB on the View label and select Constrain To View Border.
Bizzare to say the least. Is this a label that you created through just adding text that is attached to a view or is this a label that came came in with the view?
It looks almost like a label you created. So, how was the label created?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
This is label of view, not separate text. But I have checked, based on Brendan's tip, to switch property "Constraint to view border". It seems that there is an influence, but in oposite way, this property must be unchecked to keep correct position. I think that this should work reverse, or not?
Label was created trough drawing view dialog.
Petr
you saved me headaches. Every iso view label has been shifting for me and if I move it back and then close and open the problem pops back up. Thanks for this helpful tip. I have now turned off (constrain to view border) in my problematic views and my troubles have gone away.
