Inventor General
safiredesignengineers
Message 1 of 22 (329 Views)
inventor simulation testing counter balances on fabrications
329 Views, 21 Replies
12-05-2012 08:20 AM
hi group
in inventor 2013 simulation what is the way to test a fabrication for counter balanced weight stability?
if you see the enclosed rough assembly. I have been playing with variouse stuff and not getting the results i want.
the idea is to work out how much weight the arm will hold without tipping over. and then by increasing the base size and weight  or arm length i can then work out the ultimate design for my needs.
the way i want it to work is so that the base is just sitting on the floor as in real life with gravity and weight keeping it there and then as i apply weight to the arm see the tipping or load effect.
this upload is simple and i constrained the base via an axis on the edge put as soon as i run the symulation it just tips over and it shouldnt?
I have tried many other things but get a variety of results like the base suddely flying off and a thousand miles an hout due to the contacts used ?
any help on the best way to do this type of set up?
regards Adrian
*Expert Elite*
blair
Message 2 of 22 (323 Views)
Re: inventor simulation testing counter balances on fabrications
12-05-2012 08:56 AM in reply to: safiredesignengineers
I might have my software mixed up (Mech Sim vs Inventor Sim), but I would think "soft-springs on the base corners. As soon as you get a negitive result on a spring it's begining to lift up and tip over.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
*Expert Elite*
JDMather
Message 3 of 22 (321 Views)
12-05-2012 09:00 AM in reply to: safiredesignengineers
I think I would use Spatial and 3D Contact rather than Revolution or Cylindrical joints.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
*Expert Elite*
blair
Message 4 of 22 (314 Views)
12-05-2012 09:14 AM in reply to: safiredesignengineers
I guess that as soon as the CG moves beyond the edge of the base it should become unstable and start to tip over.
Win7-64
Message 5 of 22 (309 Views)
12-05-2012 09:25 AM in reply to: blair
Hi Blair
but the centre of gravity is set low in the centre of the base?
regards Adrian
Message 6 of 22 (308 Views)
12-05-2012 09:27 AM in reply to: JDMather
Hi JD
using spatial can have funney effects on a test like this, like the base entering the floor, or the assembly suddenly flying off.
I have played with settings to adjust this but it should be simpler.
regards Adrian
*Expert Elite*
JDMather
Message 7 of 22 (293 Views)
12-05-2012 10:34 AM in reply to: safiredesignengineers
I think the key will be to get to correct properties for the 3D Contact.
It looked to me like your direction of Gravity was backwards.
For the Cylindrical joint to act appropriately (if even possible) I think you will need to edit the Joint Torque Properties.
Similar problems have come up here in the past (perhaps by you?), but I don't recall the solution.  Perhaps a search would turn up discussion the "Desker".
Message 8 of 22 (287 Views)
12-05-2012 10:43 AM in reply to: JDMather
Hi Jd
Yes sorry i did have the gravity the wrong way! this is just a quick test file that i could upload.
and yes the similer problem has come up posted by me, but this time i thought by uploading a simple assembly it might provoke a simple method by somone.
there must be a simple good solution as anyone that fabricates stuff usining inventor will want to run tests like this on the potential work.
A
*Expert Elite*
blair
Message 9 of 22 (284 Views)
12-05-2012 10:50 AM in reply to: safiredesignengineers
Is this a static item, where the unit is not moving, if so then there is not a stability triangle required for unit. As soon as the C/G moves beyond an edge or hinge point the unit will tip. If this is a dynamic unit that is in motion as the C/G moves outside of the stability triangle then the unit will become unstable and tip.
Win7-64
*Expert Elite*
JDMather
Message 10 of 22 (278 Views)
12-05-2012 10:55 AM in reply to: safiredesignengineers
Might be a bad time to ask questions like this.
There seems to be reduced participation here by the Deskers between AU and Christmas.
Maybe try over here http://beta.autodesk.com
or
bump this thread after the new year if they don't come along and respond before then.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
