I am having an issue with pipe and tube routing in inventor. I am new to it and every once in a while a route that i create turns red in the browser bar, I also noticed that a few of the routes have issues where the adaptivity gets turned off by itself. I assume this has something to do with the route turning red. Any help is appreciated.
thanks,
inventor 2014 professional
Can you post a screen shot of the browser bar with the errors? Maybe a shot of your route as well if possible?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
There was an error because my minimum pipe length in tube and pipe was exceeded. I increased the length of the connection and it went away.
thanks
