Inventor General
Active Member
nickor07
Message 1 of 3 (229 Views)
inventor crash
229 Views, 2 Replies
10-06-2011 11:18 PM
I am in the process of doing my first Inventor job and run into a big problem. The job has recently been issued for approval but the client has returned with the comment that they want to remove one of the two pools from the drawing. I deleted the pool in question and all of its related piping and that all seemed to be fine in the .iam file.
Then problem which I have now encountered is when I try to open my related .dwg file it starts to load up the drawing but then it causes inventor to crash. I really don’t want to start again because the drawing was complete and I will be wasting alot of time trying to re-create what I already had.
Can you think of anyway that I can recover the .dwg file??
Product Support
VinodBalasubramanian
Message 2 of 3 (225 Views)
Re: inventor crash
10-07-2011 12:14 AM in reply to: nickor07
Can you able to submit a crash report. If so do send one and provide us the email address you have used. This would help to investigate further.
Meanwhile you could try using Task scheduler and select Update Design -> Create a new task -> Add your drawing file.
In the options, you can try to select the rebuild all. This might help to fix your drawing, if there is no huge data corruption. Please see attached.
Vinod Balasubramanian
PaulMunford
Message 3 of 3 (220 Views)
Re: inventor crash
10-07-2011 12:43 AM in reply to: nickor07
have you tried opening the drawing in defered up-date mode?
In the 'Open' dialouge select your drawing and then click the 'Options' button. Check 'Defer updates'. now click the 'open' button to open your drawing.
If this gets you in - you could try deleting any ballons or parts list tables that need to be updated, I have found that these can cause problems in drawings if they are reading from a large assembly that needs a lot of updates.
You could also try turning off color in your views, f you have any.
When you've had a chance to examine your darwing for issues, go to 'Tools' > 'Document settings' and un check 'Defer updates' to get the rest of your drawing to load.
Let us know how you get on!
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
