Inventor Forum
inventor and solidworks
3 REPLIES 3
skyngu
760 Views, 3 Replies
hi,
I want to install inventor (2012) and solidworks (2011) in the same computer. each software will be used for different job
Is there any issue I need to be aware of?
thanks a lot
Autodesk Inventor Professional 2019
3 REPLIES 3
JDMather
in reply to: skyngu
Why would there be an issue?
I have run Inventor, SolidWorks and Pro/E side-by-side for years.  The only problem I see is Inventor is increadibly slow to boot or resume from Sleep mode compared to the other two.  Once running though it is fine.
joyvettom
in reply to: JDMather
Sir, can you please advise me the method for installing Autodesk Inventor Pro 2023 and SOLIDWORKS 2023 in same computer?
Anticipating a remedial solution.
Best regards
Joy
JDMather
in reply to: joyvettom
@joyvettom
I don’t know what this means?
What do you need to remedy?
You install Inventor and SOLIDWORKS just like you install any other Windows OS software.
Exactly what issue are you experiencing?
