I don't know if this issue happen to some of you guys, but since i install the hotfixes from vault 2013 i can't load the vault add-in.
is there anyone with the fix for this or that have the same problem?
thanks
Solved by David_Early. Go to Solution.
for my case I had to uninstall vault 2013 and install it again, but this time no hotfixes were runned.
this also worked for the office add-in, since it had gone also.
I hope this issue could be solved, because hotfixes to create other issues... is not ok.
my office add-in is not working after all.
but the inventor add-in is loaded
No further info on this topic, comment from Autodesk. This issue is running for a month now. Action!!!!
greetings
DE
Had the same problem. Open Word, Rclk on the Toolbar header and pick "Customize Quick Access Toolbar" which opens the Word Options Dialog box. Pick "Add-Ins" from the left side menu.Pick "COM Add-ins" from the dropdown at the bottom of the dialog box. Pick "Go". You should see Autodesk Vault Addin for Office 20__. Pick it and pick "Add"
then OK
Hope that helps
