Using: Inventor 2013
Win 8 64 bit
I am having a problem with inventor 2013, about Mold design. When i create a mold desing.iam, every command is not available to use... after that i downloaded sp1.1 but nothing change.
Solved by JDMather. Go to Solution.
Post screen shot.
Do you know of anyone using this on Win 8 OS?
From your second shot you are not even showing your Tooling environment.
Check the Add-ins.
Is there a solution t this? i am expierencing the same problem. Windows 8, Inventor 2013, 64 bit, No tooling ribbon or commands
Here is a screen shot, no ribbons at the top, but you can see the toolbars should be there, Have try a repair , and a reinstall, this work fine on inventor 2012 with same hardware, and i have try it on second machine, with same results.
I think i have solve the problem. I reinstall service pack 1 for inventor, and apply the latest hotfix and everything seems to be working.
