Inventor Forum
inventor 2013: Mold design problem
6 REPLIES 6
roicehat
1468 Views, 6 Replies
Using: Inventor 2013
Win 8 64 bit
I am having a problem with inventor 2013, about Mold design. When i create a mold desing.iam, every command is not available to use... after that i downloaded sp1.1 but nothing change.
6 REPLIES 6
JDMather
in reply to: roicehat
Post screen shot.
Do you know of anyone using this on Win 8 OS?
The CADWhisperer YouTube Channel
roicehat
in reply to: JDMather
I've never seen anyone use Inventor on the win 8. This is when I update sp1.1
JDMather
From your second shot you are not even showing your Tooling environment.
Check the Add-ins.
cdscott26
Is there a solution t this?  i am expierencing the same problem.  Windows 8, Inventor 2013, 64 bit, No tooling ribbon or commands
cdscott26
in reply to: cdscott26
Here is a screen shot,  no ribbons at the top, but you can see the toolbars should be there,  Have try a repair , and a reinstall,  this work fine on inventor 2012 with same hardware, and i have try it on second machine, with same results.
cdscott26
I think i have solve the problem.  I reinstall service pack 1 for inventor, and apply the latest hotfix and everything seems to be working.
