Inventor General
none1
Message 1 of 24 (456 Views)
Accepted Solution
inventor 2011 will not give me an angle dim
456 Views, 23 Replies
11-13-2012 08:58 AM
Is there any way of telling inventor NO NOT LINEAR, ANGULAR.
I just want to create an angle dim between two sketchs lines I have created.  The only option it gives me is verrtical, horizontal or aligned.  NEED A SIMPLE ANGLE DIMENSION.  Should take more than 2-3 seconds, but after ten minutes I have over 60 linear dims that are vertical, horizontal or aligned.
Another question since inventor spits out linear dims to begin with, why not have an angular option on the right click?   Is there an LOGICAL reason why this option does not ALREADY exist?
Valued Mentor
mpatchus
Message 2 of 24 (453 Views)
Re: inventor 2011 will not give me an angle dim
11-13-2012 09:11 AM in reply to: none1
If those are your only options, then the two lines are parallel and an angular dimension is not possible.
Inventor will always apply an angular dimension when two lines are selected that are not parallel.
Make sure you are dimensioning the lines, and not POINTS on the lines.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
none1
Message 3 of 24 (442 Views)
11-13-2012 10:09 AM in reply to: mpatchus
Thanks Mike, but i have $10,000 that says these two lines are 72.0 degrees apart, since that is how they were created in Sketch (and in no way parallel).   If you look at your hand and spead your thumb and index finger apart that is about the angle that these 2 lines are at.
Distinguished Mentor
john.retzlaff
Message 4 of 24 (434 Views)
11-13-2012 10:21 AM in reply to: none1
Can you post the file?
John Retzlaff
none1
Message 5 of 24 (423 Views)
11-13-2012 10:46 AM in reply to: john.retzlaff
Not legally without written permission! This is not worth going to jail over.  This must be another one of the many random bugs that comes each time a software updates on my pc.  Sometimes inventor and acad will not even reconize an intersection.
Am I the only person on these groups that works with proprietary rights protected material?
none1
Message 6 of 24 (417 Views)
11-13-2012 10:51 AM in reply to: none1
May have found the problem, the two lines are not in the same sketch.  Eventhough that should not make a difference, I am going to combine into 1 sketch to see if that allows me to create an angular dim.
none1
Message 7 of 24 (415 Views)
FIXED Re: inventor 2011 will not give me an angle dim
11-13-2012 11:03 AM in reply to: none1
Sure enough inventor did not like that fact that the two lines were not in the same sketch.  Not sure why that would mater except for that fact that software writting is not what it used to be.
Is this a commonly known rule for inventor?
Valued Contributor
nannerdw
Message 8 of 24 (410 Views)
Re: FIXED Re: inventor 2011 will not give me an angle dim
11-13-2012 11:17 AM in reply to: none1
If you want to include sketch or model geometry from outside the sketch, you have to use the "Project Geometry" command.  Use this comand sparingly, though, since any references to deleted geometry will become broken and have to be manually redefined.
-Using Autodesk Inventor Professional 2012
none1
Message 9 of 24 (379 Views)
11-13-2012 02:14 PM in reply to: none1
Thank you, I did forget to add that the sketch(s) were not created in part mode.  The sketches  with the issue were in the drawing, angle dims needed to be created to fully explain all geometry. The dimensioning problem was from annotate menu (so the sketches were closed or finished) when trying to dimension the sketches this is where the issue occured.
So this issue was with the sketches created on the drawing, not the modeling sketches.  Important difference.
*Pro
sbixler
Message 10 of 24 (348 Views)
11-14-2012 06:41 AM in reply to: none1
Seems to work as you would expect in 2013.  General Dimension tool, used on two lines created in different sketches (on the same view), gives an angle dimension.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
