Inventor Forum
inventor 2010 add-inns not there
4 REPLIES 4
289 Views, 4 Replies
Hi Y'all
Ex AutoCad,SolidWorks user looking at Inventor.
Loaded 2010 up to SP4. Add-ins appear to be in Bin folder and show as loaded in Tools/Add-in manager but do not show in Add-in list on the Ribbon.
Tried online autodesk fixes with no luck.
Hope you can help
kiwicadman
4 REPLIES 4
Now when I add in after opening the Stress Analysis tool bar lights up but then goes grey again.
Rob,
JDMather
kiwicadman
This has come up here several times - a search might turn up the solution.
What was the url of the Autodesk "fix" that you tried?
Curtis_Waguespack
Hi kiwicadman,
If one of these is what you've tried, you might try the other:
Inventor add-in repair utility
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13404176&linkID=9242018
How to Register your missing Add-Ins
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13909656&linkID=9242018
I hope this helps.
Curtis
in reply to: Curtis_Waguespack
Hi Curtis:
Yes I did try the drop in file. Coppied the contents into a txt file, changed it to cmd, placed it in the bin folder and ran it,
I don't remember from the old days how to do the dir thing to navigate in DOS.
I assume that both fixes do thesame thing.
JD has sujested a clean uninstal/reinstal.
Thanks.
Rob
