Inventor General
Active Member
reply2.vibh
Message 1 of 4 (273 Views)
internal tube design problem
273 Views, 3 Replies
04-17-2013 08:30 AM
hi
I was trying to create Aircraft pitot tube using inventor and got the problem of internal tube designing in the connector section. Please see the attached files.
I am having problem designig the internal part of the end connector section where the internal tube  from the probe goes up bends and connects to a tube with end connector via an accumulator. (as shown in the  picture attached - Pitot.tube_abnormal.procedures-1_A300-600_Prunep.55)
please help me give sme suggestion
Vishal
JDMather
Message 2 of 4 (263 Views)
Re: internal tube design problem
04-17-2013 08:36 AM in reply to: reply2.vibh
Looks like Sweep should do it.
Can you attach the file(s) here?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
reply2.vibh
Message 3 of 4 (254 Views)
04-17-2013 08:40 AM in reply to: JDMather
How could sweep help do an internal design specially when outer casing in
planer and the internal in circular /..
With Regards*
Vishal Bhatnagar*
Active Member
reply2.vibh
Message 4 of 4 (247 Views)
04-17-2013 08:47 AM in reply to: JDMather
How can sweep help in this ??
could u upload a tutorial or so about this particular design ??
please fine the files attached in my original post as well as the reference file below (some how it got removed)
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
