I have no idea what is going on. But, i hope you do...
I have a model with 12 circular connectors placed (constrained) in the housing surface. well 11 of them are. The last one WILL NOT behave. when i use the insert constraint (or any constraint) the model of the connector modifies itself and becomes a new model with errors.
i have deleted it from the assembly, saved, closed, opened and when re - inserted have the same problem.
I have re-saved the connector model from its original location to the library folder, re-inserted and got the same problem. The connector model is fine in the assembly up until i try to constrain it.
all the connectors were drawn the same way, using parameters, and saved into the same library folder.
I don't understand how adding a constraint can cause a model in a diffferent folder to be modified.
Please help me understand what is going on here.
thanx!!
