I have been using the frame generator quite often and recently the insert frame command is not working properly. I would like to know if there is a fix/patch for this problem or do I have to re-install the program??? I am very frustrated with this problem as I do alot of structural design and the insert frame command comes in very very handy.
HELP!!!!!!!!!!!!
Solved by Curtis_Waguespack. Go to Solution.
Need a lot more information, please. What version of Inventor, what are your system specs,... and what led up to this problem? Did it just quit working one day?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
yeah it kind of just quit working on me ;( , my system specs are:
amd 64x2 5000+
nvidia geforce 8800 gts 512
windows xp 😞
Inventor suite 2011
This is my work PC not my home PC so if there is a problem I would like to get it fixed. Thanks for any help you can provide as this problem is costing me time/money.
Check Tools \ Add Ins. make sure your Frame generator is set to Startup/Loaded.
Chris Benner
Hi derekmunn,
This is a bit of a long shot, but is it possible that the Insert dialog box is just coming up off screen?
See this link to test for this scenario:
http://inventortrenches.blogspot.com/2011/01/missing-dialog-box.html
I hope this helps.
Curtis
