Inventor Forum
incorrect parameter value??
8 REPLIES 8
Message 1 of 9
420 Views, 8 Replies
I am trying to insert a parameter name (d1) into the equation field of
another parameter (d13).
The value (d1) is showing up 2.54 times larger when inserted into this
equation field.
This parameter (d13) has a "ul" unit designation. Is this "ul" designation
causing the problem? Why are parameters being multiplied be 2.54 when
inserted into the equation??
Scott
8 REPLIES 8
Message 2 of 9
Are you working in both English and Metric? 2.54 is a conversion factor
number as is .03937.
I haven't seen this problem, but it sure sounds like it's trying to get an
inch value from a metric? Are both parameters using the same units?
Good luck.
gcooper
"scott peebles" wrote in message
news:2DF5B03CB31D6C56EBCA2218962CBA0A@in.WebX.maYIadrTaRb...
> equation field.
designation
> Thanks
> Scott
Message 3 of 9
It appears my inch value is being converted to centimeters, but I can't
figure why. I am working in inches. The unit designation for the problem
parameter is "ul".
"GCooper" wrote in message
news:EDD4D268518F21773820C6383522F38B@in.WebX.maYIadrTaRb...
> Good luck.
> gcooper
> > equation field.
> designation
> > Thanks
> > Scott
Message 4 of 9
Try entering "d1 / 1 in" or "isolate(d1;ul;in)" for the value in d13.
equation field.
Scott
Message 5 of 9
Strange. Better call your VAR and tellem it's broken and you want free beer
to compensate for your pain and suffering.
Was this part ever metric? Can you duplicate this in another part? If it's
not proprietary post it to CF and I'll take a look.
gcooper
news:7C2DDA8159C4FEBEC8D30503B6928708@in.WebX.maYIadrTaRb...
> parameter is "ul".
an
> > Good luck.
> > gcooper
> > > equation field.
> > designation
> > > Thanks
> > > Scott
Message 6 of 9
The base unit of Inventor is centimeters hence the 2.54 coversion. You need
to make the function that has d1 in it come out as ul. If the units don't
match you get weird numbers.
KAthy Johnson
news:B567348C7EA54A6503C302F719F03F33@in.WebX.maYIadrTaRb...
beer
> gcooper
problem
> > parameter is "ul".
factor
get
> an
> > > Good luck.
> > > gcooper
of
this
> > > > equation field.
> > > designation
when
> > > > Thanks
> > > > Scott
Message 7 of 9
A few ways to skin the cat but one way is to use the isolate function:
isolate(d1:ul:in) assuming that d1 is in units of inches
another is
d1/ in (again assuming that d1 is in inches)
when you use mixed units (ul and in) you get into all sorts of hairy
problems...
BTW ul stands for unitless
for more info download the tutorial "Introduction to Inventor Functions" on
my site
Sean Dotson, PE
http://www.sdotson.com
remove all #s from email
> equation field.
designation
> Thanks
> Scott
Message 8 of 9
sorry Jeff, guess I should have refreshed sooner...hour and a half (wow, I'm
getting slow..)
Sean Dotson, PE
"Sean Dotson" wrote in message
news:0DBB8E096F2E6E8B5C5475107C00A198@in.WebX.maYIadrTaRb...
> another is
> problems...
on
> my site
> Sean Dotson, PE
> > equation field.
> designation
> > Thanks
> > Scott
Message 9 of 9
8~) Absolutely no prob. Thanks for the heads up on the tutorial. I'll have
to take a look.
news:3A994FA074EE7D8C5E988DD24CFA177B@in.WebX.maYIadrTaRb...
getting slow..)
Sean Dotson, PE
