I have stored a few images in the Vault library that are used by my titleblock.
The problem is that when someone tries to check in a drawing Vault sees the embedded image in the title block and says the drawing can't be checked in because the images are already in the Vault as read-only.
Any ideas on what to do?
thanks,
elise
Solved by Account_Deleted. Go to Solution.
When adding the images do you uncheck the link option? If not, that should fix the problem as it should not need the bitmap file anymore as the default link option still requires the bitmap file to exist on the computer.
If you would like to keep it like it is then you will need to checkout both the drawing and the bitmap file.
