Inventor Forum
ilogic shortcut key
61 REPLIES 61
Message 1 of 62
Ktelang
9264 Views, 61 Replies
ilogic shortcut key
Is there any command/option to add a keyboard shortcut for ilogic rule ?
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
61 REPLIES 61
Message 61 of 62
mguman
in reply to: MjDeck
Hi Mike,
Could you explain this code to me? I have created a rule where Inventor creates a PDF from the IDW upon save (I assume this is a common rule). But I want to use a keybind instead of having it make a PDF upon saving the file.
Edit:
I found a different solution to my answer. I simply imported my iLogic rule in the 'Keyboard' tab in the 'Customize' environment under 'Tools'. Assigned a keybind to it and it did the job as expected!
Message 62 of 62
MjDeck
in reply to: mguman
Hi @mguman , glad you found it. That's the best way to do it in Inventor 2023 and later. It was not available before Inventor 2023.
Mike Deck
Software Developer
Autodesk, Inc.
Autodesk Customer Advisory Groups
