Inventor Forum
ilogic rule parameter gets stuck regardless of change
4 REPLIES 4
an42drew
436 Views, 4 Replies
This is the code:
If SDU_Through_Ceiling = "Yes" Then
Parameter("Raceway Roof:1", "Width") = Raceway_Width
Parameter("Raceway Roof:2", "Width") = Raceway_Width
Parameter("Raceway Roof:3", "Width") = Raceway_Width
Component.IsActive("Riser Top:1") = True
Component.IsActive("Riser Top:2") = True
Component.IsActive("Riser Infil:5") = True
Component.IsActive("Riser Infil:6") = True
Component.IsActive("Riser Infil Top:1") = True
Component.IsActive("Riser Infil Top:2") = True
Component.IsActive("Riser Panel:1") = True
Component.IsActive("Riser Panel:2") = True
Else If SDU_Through_Ceiling = "No" AndAlso Width < 2500
Parameter("Raceway Roof:1", "Width") = Raceway_Width+Riser_Width+Riser_Width
Component.IsActive("Riser Top:1") = False
Component.IsActive("Riser Top:2") = False
Component.IsActive("Riser Infil:5") = False
Component.IsActive("Riser Infil:6") = False
Component.IsActive("Riser Infil Top:1") = False
Component.IsActive("Riser Infil Top:2") = False
Component.IsActive("Riser Panel:1") = False
Component.IsActive("Riser Panel:2") = False
Else If SDU_Through_Ceiling = "No" AndAlso Width >= 2500 And Width < 4500 Then
Parameter("Raceway Roof:2", "Width") = Raceway_Width+Riser_Width
Else If SDU_Through_Ceiling = "No" AndAlso Width >= 4500 Then
Parameter("Raceway Roof:3", "Width") = Raceway_Width+Riser_Width
The red text is where i am having problems.
The rule seems to run fine up to the point of "Width" going over 4500.
The parameters Parameter("Raceway Roof:1", "Width") Parameter("Raceway Roof:2", "Width") Parameter("Raceway Roof:3", "Width")
dont change no matter what value i give them
Any help would be much appreciated
4 REPLIES 4
akhidrosyidi
in reply to: an42drew
hi, can you attach the model included your ilogic here?
daily works with :
Autodesk Inventor Profesional 2014.
AutoCAD Mechanical 2014.
Autodesk Vault Profesional 2014.
an42drew
I'd rather not put the whole model on, but i will try tonight to make a smaller model with just the problem parts.See if i can work it out that way. If not i will put that one on here.
I keep staring at the code but just cant seem to see whats wrong. It must be something else conflicting with this part.
an42drew
Here is a small assembly with the bit i am struggling with
In the last piece of the code
 Raceway Roof 2 should be a Riser Width shorter than the other two but it isnt
an42drew
I feel like a bit of a fool, and find it hard to believe i havent come across this situation before.
Turns out the problem was not with the code but the fact i was trying to make the same parameter in duplicated components behave differently.
I simply solved this by saving the component two more times under different names and adapted the code to suit those names.
Oh well you live and learn!
Thanks anyway
