Inventor General
Active Member
an42drew
Message 1 of 5 (200 Views)
ilogic rule parameter gets stuck regardless of change
200 Views, 4 Replies
02-14-2014 12:49 PM
This is the code:
If SDU_Through_Ceiling = "Yes" Then
Parameter("Raceway Roof:1", "Width") = Raceway_Width
Parameter("Raceway Roof:2", "Width") = Raceway_Width
Parameter("Raceway Roof:3", "Width") = Raceway_Width
Component.IsActive("Riser Top:1") = True
Component.IsActive("Riser Top:2") = True
Component.IsActive("Riser Infil:5") = True
Component.IsActive("Riser Infil:6") = True
Component.IsActive("Riser Infil Top:1") = True
Component.IsActive("Riser Infil Top:2") = True
Component.IsActive("Riser Panel:1") = True
Component.IsActive("Riser Panel:2") = True
Else If SDU_Through_Ceiling = "No" AndAlso Width < 2500
Parameter("Raceway Roof:1", "Width") = Raceway_Width+Riser_Width+Riser_Width
Component.IsActive("Riser Top:1") = False
Component.IsActive("Riser Top:2") = False
Component.IsActive("Riser Infil:5") = False
Component.IsActive("Riser Infil:6") = False
Component.IsActive("Riser Infil Top:1") = False
Component.IsActive("Riser Infil Top:2") = False
Component.IsActive("Riser Panel:1") = False
Component.IsActive("Riser Panel:2") = False
Else If SDU_Through_Ceiling = "No" AndAlso Width >= 2500 And Width < 4500 Then
Parameter("Raceway Roof:2", "Width") = Raceway_Width+Riser_Width
Else If SDU_Through_Ceiling = "No" AndAlso Width >= 4500 Then
Parameter("Raceway Roof:3", "Width") = Raceway_Width+Riser_Width
End If
The red text is where i am having problems.
The rule seems to run fine up to the point of "Width" going over 4500.
The parameters Parameter("Raceway Roof:1", "Width") Parameter("Raceway Roof:2", "Width") Parameter("Raceway Roof:3", "Width")
dont change no matter what value i give them
Any help would be much appreciated
Active Contributor
akhidrosyidi
Message 2 of 5 (181 Views)
Re: ilogic rule parameter gets stuck regardless of change
02-14-2014 07:53 PM in reply to: an42drew
hi, can you attach the model included your ilogic here?
daily works with :
Autodesk Inventor Profesional 2014.
AutoCAD Mechanical 2014.
Autodesk Vault Profesional 2014.
Active Member
an42drew
Message 3 of 5 (176 Views)
02-15-2014 03:14 AM in reply to: an42drew
I'd rather not put the whole model on, but i will try tonight to make a smaller model with just the problem parts.See if i can work it out that way. If not i will put that one on here.
I keep staring at the code but just cant seem to see whats wrong. It must be something else conflicting with this part.
Active Member
an42drew
Message 4 of 5 (165 Views)
02-15-2014 12:38 PM in reply to: an42drew
Here is a small assembly with the bit i am struggling with
In the last piece of the code
 Raceway Roof 2 should be a Riser Width shorter than the other two but it isnt
Active Member
an42drew
Message 5 of 5 (149 Views)
02-16-2014 12:42 PM in reply to: an42drew
I feel like a bit of a fool, and find it hard to believe i havent come across this situation before.
Turns out the problem was not with the code but the fact i was trying to make the same parameter in duplicated components behave differently.
I simply solved this by saving the component two more times under different names and adapted the code to suit those names.
Oh well you live and learn!
Thanks anyway
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
