I am looking to create a pattern for 2, 3 and sometimes 4 individual parts. Let's call them part A B C and D. The pattern will have equal spacing between each part and will always follow the same order, ABCDABCDABCD the problem is, I may not always have an even number of instances. I can for example need 10 instances of the parts total so the pattern will be missing two parts from a standard pattern ABCDABCDAB. I am trying to figure out how to write this so I can select a number of instances even or odd and have ilogic figure out what the pattern number for each needs to be.
I could use if statments, but I need the pattern adjustable from 2 to 50 instances, with the ability to select how many individual parts are present, wheter it is AB only, ABC, or ABCD.
Example patterns with 2 parts and 7-10 total instances
ABABABA (7)
ABABABAB (8)
ABABABABA (9)
ABABABABABA (10)
Example patterns with 3 parts and 8-11 total instances
ABCABCAB (8)
ABCABCABC (9)
ABCABCABCA (10)
ABCABCABCAB (11)
Example patterns with 4 parts and 8-13 total instances
ABCDABCD (8)
ABCDABCDA (9)
ABCDABCDAB (10)
ABCDABCDABC (11)
ABCDABCDABCD (12)
ABCDABCDABCDA (13)
Any help would be appriciated.
Below if just a pattern with two individual parts alternating, but like I said I would like to specify the total number of parts and have ilogic determine which pattern will need to have instances added or removed.
You might want to post this here? From the standard install I am not sure anything can be offered.
Don
