Inventor General
Valued Mentor
Rich.O.3d
Message 1 of 6 (843 Views)
ilogic plot stamp - Curtis I need help please
843 Views, 5 Replies
06-06-2012 04:39 PM
I have a plot stamp im trying to tweek.
They were put together in a hurry from Curtis_w's posts and blog.
I dont have time to rework due to a massive project deadline fast approaching.
I had two rules showing date and time etc that were set to run on event trigger file save.
Now i need to add drafter name to this.
What i was trying to do was check if the custom prop PlotAuthor exists, and create it if it didnt.
Then I want to set the PlotAuthor to = the inventor username.
I failed in the timeframe i had :smileysad:
I intended to combine these into one rule but dont have the time to work it out.
Curtis, you seem to have this stuff wired...if not combining them could you give me hand on at leat making rule 3 work please.
Any help would be greatly appreciated.
rule 1
PlotDateStamp
Dim odrawdoc As DrawingDocument
odrawdoc = ThisApplication.ActiveDocument
customPropertySet = odrawdoc.PropertySets.Item("Inventor User Defined Properties")
Try
      prop = customPropertySet.Item("Plotdatestamp")
Catch
      customPropertySet.Add("", "Plotdatestamp")
End Try
Try
Dim PlotDate As Date
PlotDate = Now
iProperties.Value("Custom", "Plotdatestamp") = PlotDate
Catch
End Try
InventorVb.DocumentUpdate()
rule 2
PlotTimeStamp
Try
      prop = customPropertySet.Item("Plottimestamp")
Catch
      customPropertySet.Add("", "Plottimestamp")
End Try
Try
Dim PlotTime As String
PlotTime = Now.ToShortTimeString
iProperties.Value("Custom", "Plottimestamp") = PlotTime
Catch
End Try
rule 3
PlotAuthorStamp
myName= ThisApplication.GeneralOptions.UserName
If iProperties.Value("Summary", "PlotAuthor") <> myName Then
iProperties.Value("Summary", "PlotAuthor") = myName
End If
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Curtis_Waguespack
Message 2 of 6 (835 Views)
Re: ilogic plot stamp - Curtis I need help please
06-06-2012 06:44 PM in reply to: Rich.O.3d
Hi richos69,
This should work (I didn't test it):
'rule 3
'PlotAuthorStamp
If iProperties.Value("Summary", "Author") <> myName Then
iProperties.Value("Summary", "Author") = myName
End If
 Or if you need to use "PlotAuthor", then you'll want to go the custom property route, like the others. I'll have another look, when I get a chance and have a go at combining them.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Valued Mentor
Rich.O.3d
Message 3 of 6 (830 Views)
06-06-2012 07:29 PM in reply to: Curtis_Waguespack
thanks curtis
the Author property is already used in the title block for other info.
I need it for showing who plotted the drawing, as opposed to who created it.
I was going to run it on file open and on file save so if a person other than the document custodian (designer) opened it and made mods then printed it would leave a paper trail. (Large consultancy with a few rouge drafters causing problems)
Thats why i wanted to create the custom prop PlotAuthor from the application.username
CAD Management 101:
mrattray
Message 4 of 6 (813 Views)
06-07-2012 05:29 AM in reply to: Rich.O.3d
The problem is with this line:
Try using:
myName = ThisApplication.UserName
 This is in addition to the problem Curtis pointed out. To elaborate for him, you cannot add a property to the Summery prop set. You have to use the Custom prop set or one of the predefined properties in Summery.
So your code should look like:
'rule 3
'PlotAuthorStamp
myName= ThisApplication.UserName
If iProperties.Value("Custom", "PlotAuthor") <> myName Then
iProperties.Value("Custom", "PlotAuthor") = myName
End If
Mike (not Matt) Rattray
Curtis_Waguespack
Message 5 of 6 (794 Views)
06-07-2012 09:16 AM in reply to: Rich.O.3d
Hi richos69,
Here is a rule that combines the three rules. I used mrattray's suggestion as well, but I didn't see any difference in using ThisApplication.UserName vs. ThisApplication.GeneralOptions.UserName. Attached is an example file for reference just in case my setup was a departure from yours, so you can compare. Or in case it helps someone in the future.
I hope this helps.
Curtis
'define the drawing
'define the property set
'define the date string
PlotDate = Now
'define the time string
'define the user name string
Dim PlotName As String
PlotName= ThisApplication.UserName
'---------------- find or create custom properties -------------
'look for the custom propety and add it if not found
Try
Catch
End Try
Try
Catch
End Try
Try
	prop = customPropertySet.Item("PlotAuthor")
Catch
	customPropertySet.Add("", "PlotAuthor")
End Try
'---------------- set the property values -----------------------
'set the date property
'set the timeproperty
'set the name property
iProperties.Value("Custom", "PlotAuthor") = PlotName
'update the file
Valued Mentor
Rich.O.3d
Message 6 of 6 (764 Views)
06-07-2012 05:39 PM in reply to: Curtis_Waguespack
thanks for the input mrattray
Curtis you are an absolute champion...that works perfectly.
It would have taken me ages to figure it out.
I havent programed much since cobol/fortran days.
Im liking the ilogic, i might get me some training :smileywink:
(if i still need it after studying the crap out of your blog...nice work btw)
CAD Management 101:
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
