Inventor Forum
ilogic idw dimension problem
5 REPLIES 5
Retselnitram
814 Views, 5 Replies
I have a tube and with ilogic I have different amounts of holes depending on how long the tube.
How can make it so that it always dimensions the holes properly.
It will dimension some holes twice and some holes it doesn't dimension at all.
5 REPLIES 5
innovatenate
in reply to: Retselnitram
Lester,
Can you upload a sample file to investigate?
Nathan Chandler
Principal Specialist
mrattray
How are you applying the dimensions?
Mike (not Matt) Rattray
Retselnitram
in reply to: innovatenate
Here it is.
innovatenate
Without going into VBA and the API, I don't believe there's a way to do this. You may find better assistance with that in the customization forum. My thought is that the ordinate dimensions would need to be deleted and recreated any time the drawing view is updated to prevent the 'sick' dimensions.
Rather than putting ordinate dimensions on the drawing view (and dealing with custom code), have you considered using a hole table? I believe that the hole table will remain associative with the view.
Another thought is to create an iAssembly (warning: iLogic will not persist in iAssembly member files). A single view of the  iAssembly may be created, with a generic table associated to it. Something like this:
Nathan Chandler
mrattray
I agree with Nathan, Lester.
Although it is possible to do this with the API, it is very complicated. Here is a thread where the OP has written code to insert and detail a part: http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/iLogic-Coding-to-Create-Automated-Draw...
