Inventor General
Valued Contributor
waynehelley
Message 1 of 6 (619 Views)
Accepted Solution
ilogic - get model reference
619 Views, 5 Replies
03-08-2013 06:34 AM
Hi there,
I was wondering if there was a command that will get the file name of the model referenced in a drawing?
The reason I want to do this is because I have various programs to automate drawings, but I have to manually edit the code if i want to switch between using the code on assembly drawings and part drawings.
If i can get the model reference, I can then use a bit of extra programming to extract the extension. (i.e. .ipt or .iam)
Thanks in advance,
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2013
Windows 7 Enterprise, 64-bit
*Expert Elite*
Curtis_Waguespack
Message 2 of 6 (610 Views)
Re: ilogic - get model reference
03-08-2013 06:45 AM in reply to: waynehelley
Hi waynehelley,
You can use this:
doc = ThisDoc.ModelDocument
 I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Valued Contributor
waynehelley
Message 3 of 6 (605 Views)
03-08-2013 07:07 AM in reply to: Curtis_Waguespack
Hi Curtis, I am still having a bit of trouble.  I have tried the following but I can't seem to be able to get the command to give me the document name as text. If I run the following...
modeldoc = ThisDoc.ModelDocument
test = modeldoc.FileName(True)'with extension
MessageBox.Show(test, "Title")
I get the error...
Error in rule: Get Model Reference, in document: Get Model Reference.iLogicVb
Public member 'FileName' on type 'AssemblyDocument' not found.
Wayne Helley
Valued Contributor
waynehelley
Message 4 of 6 (603 Views)
03-08-2013 07:12 AM in reply to: Curtis_Waguespack
I am not sure if I got a bit confused about what your code was intended to be used for.  I will attach my code. You will be able to see that I get to a section where my program replaces the model reference (within a for function) and needs to know the extension
Wayne Helley
Valued Contributor
waynehelley
Message 5 of 6 (589 Views)
03-08-2013 07:33 AM in reply to: waynehelley
Just to clarify, my program is intended to be ran from a drawing, hence I need to know if the drawing is of a part or assembly.
I can make do with this for now...
extension = InputBox("Please state the file extension. '.ipt' for parts and '.iam' for assemblies", "Drawing Generator",".ipt")
Wayne Helley
*Expert Elite*
Curtis_Waguespack
Message 6 of 6 (557 Views)
03-08-2013 01:31 PM in reply to: waynehelley
Hi waynehelley,
I think this will work for you to check the file type:
 'check file type
If doc.DocumentType = kPartDocumentObject Then
MessageBox.Show("This is a part file.", "iLogic")
Else if doc.DocumentType = kAssemblyDocumentObject Then
MessageBox.Show("This is an assembly file.", "iLogic")
End if
 I hope this helps.
Curtis
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
