Morning all
I have a drawing based on an assembly, and every time the assembly changes in size, specific dimensions are not aligned anymore.
Is it possible to align specified dimensions?
Solved by Jacques.Grobler. Go to Solution.
I can have the user realign these but I would prefer if the process can be completed without user interference
And I have found the solution:
It is called "ChainSet" under Annoate > Dimension
