Inventor Forum
ilogic, Assembly save all dependants
7 REPLIES 7
Message 1 of 8
Jacques.Grobler
1853 Views, 7 Replies
Hi all
Is it possible not to have inventor prompt to save or not to save all parts in an assembly when pressing save?
I would prefer all parts to be automatically saved with no prompt box when I run thisdocument.save
7 REPLIES 7
Message 2 of 8
mrattray
in reply to: Jacques.Grobler
Try using Document.Save2
Mike (not Matt) Rattray
Message 3 of 8
Jacques.Grobler
in reply to: mrattray
Hi Mike
Sorry but I cannot find any reference to Document.Save2
Message 4 of 8
mrattray
Message 5 of 8
Jacques.Grobler
Tx Mike
As I posted my reply I stumbled upon this:
' This is the document being saved
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim oRefDoc As Document
Dim oRefDocDesc As DocumentDescriptor
' make all the referenced documents dirty
For Each oRefDocDesc In oDoc.ReferencedDocumentDescriptors
    oRefDoc = oRefDocDesc.ReferencedDocument
    oRefDoc.Dirty = True
Next
' Save the document and its dependents.
Call oDoc.Save2(True)
 which includes the Document.Save2
Message 6 of 8
Hi and thanks for your contribution.
I tried this code but got an error when one of the components was patterned and one instance of the pattern was suppressed
Error:
Error in rule: Change hood, in document: Rect Hood.iam
Object reference not set to an instance of an object.
Took my a couple of hours to find the cause because it had been working untill I suppresed an instance of the pattern through iLogic.
It seems to stumble on the mark dirty part of the refence documents, from what I can see at least (beiing the beginner programmer I am)
If I comment out the following it works again:
Next
Is there a trick to get past this? Because I need to get all the parts updated before I export them to a drawing.
Cheers
Rudrugis
Message 7 of 8
sigurdurie
in reply to: sigurdurie
I changed the Call to Save2 to:
SyntaxEditor Code Snippet
Call oDoc.Save2(True,SaveDependents)
And it seems to do what I'm after
Cheers
Rudrugis
Message 8 of 8
sigurdurie
The deeper I dig the more unnecessary the loop seems to be because from what I gather the call to Save2:
Does infact safe all dependents i.e. searches for parts marked as "dirty" and saves them if they have changed.
I might be wrong of course but maybe someone can set me straight regarding this or confirm it?
Cheers
Rudrugis
