Inventor General
Active Member
PetraM
Message 1 of 13 (1,947 Views)
illustrator export - inventor import
1947 Views, 12 Replies
11-14-2004 03:13 AM
Is it possible to import curves from illustrator or any other similar program as curves in inventor?
I want to emboss a logo of a company. I've got it as outlines in illustrator.
I really don't want to import a .bmp file into a sketch and draw over it.
Thank you for your help,
Petra
*cbliss
Message 2 of 13 (1,947 Views)
Re: illustrator export - inventor import
11-14-2004 08:26 AM in reply to: PetraM
Will Illustrator export a DXF or DWG? If so, you could import vector geometry. PetraM wrote: >Is it possible to import curves from illustrator or any other similar program as curves in inventor? > >I want to emboss a logo of a company. I've got it as outlines in illustrator. > >I really don't want to import a .bmp file into a sketch and draw over it. > >Thank you for your help, >Petra > >
*Quinn Zander
Message 3 of 13 (1,947 Views)
11-14-2004 08:39 AM in reply to: PetraM
I'd bet that illustrator could push out WMF which you could import into Acad then dump the DWG into a sketch in IV. QBZ "PetraM" wrote in message news:20853208.1100430855753.JavaMail.jive@jiveforum2.autodesk.com... > Is it possible to import curves from illustrator or any other similar program as curves in inventor? > > I want to emboss a logo of a company. I've got it as outlines in illustrator. > > I really don't want to import a .bmp file into a sketch and draw over it. > > Thank you for your help, > Petra
*Carbon
Message 4 of 13 (1,947 Views)
11-14-2004 09:35 AM in reply to: PetraM
cbliss wrote: > Will Illustrator export a DXF or DWG? If so, you could import vector > geometry. Illustrator does indeed export as dxf and dwg.
Active Member
PetraM
Message 5 of 13 (1,947 Views)
11-15-2004 02:17 AM in reply to: PetraM
Illustrator indeed does export DWG and DXF files but when I import them into inventor (or by file-open or by importing them directly into a sketch) nothing happens. It imports it but the sketch is blank.
No idea why that happens.
Won't work through exporting it to Acad because i don't have the program.
Petra
Active Contributor
Austin316
Message 6 of 13 (1,947 Views)
11-15-2004 02:54 AM in reply to: PetraM
if you've got inventor you should have autocad aswell, it comes free with it
*Finnur P. Frodason
Message 7 of 13 (1,947 Views)
11-15-2004 03:59 AM in reply to: PetraM
when exporting from Illustrator to dwg there is always errors in the dwg. You must open the file in ACAD and run "audit", mayby change things to layer 0 and even move things to a "sensible" origin. -- IV 9 / AIP 9 Finnur P. Frodason HP X4000 - dual Xeon 2.4 XP Pro SP 2 - 2GB mem Nvidia Quadro 4 980 "PetraM" wrote in message news:5070754.1100513906966.JavaMail.jive@jiveforum2.autodesk.com... > Illustrator indeed does export DWG and DXF files but when I import them > into inventor (or by file-open or by importing them directly into a > sketch) nothing happens. It imports it but the sketch is blank. > No idea why that happens. > > Won't work through exporting it to Acad because i don't have the program. > > Petra
Distinguished Contributor
stevensf
Message 8 of 13 (1,947 Views)
11-15-2004 05:11 AM in reply to: PetraM
Can you import to Illustrator from IV or Acad and have a file that can be edited? Is there any special things ou need to do in Acad or IV before youimport into Illustrator?
Fred
*Bob S.
Message 9 of 13 (1,947 Views)
11-15-2004 06:03 AM in reply to: PetraM
I haven't worked with Adobe Illustrator un awhile, so this info might not be completely accurate. Illustrator seems to work best if the import files are postscript, which you should be able to get from either acad or iv by setting up a postscript printer that prints to a file, then import that into illustrator. Hope that helps. Bob S. "stevensf" wrote in message news:16502343.1100524299478.JavaMail.jive@jiveforum2.autodesk.com... > Can you import to Illustrator from IV or Acad and have a file that can be edited? Is there any special things ou need to do in > Acad or IV before youimport into Illustrator? > Fred
Active Member
PetraM
Message 10 of 13 (1,947 Views)
11-15-2004 07:28 AM in reply to: PetraM
Thanks a lot!!
i managed to open a wmf file in acad and then import it into inventor and it works. (Had to install acad first :smileyhappy:
How i'm gonna get the dimensions and the position right is another story since i can't really use acad. But i'll learn.
Thank you very much again!
Petra
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
