I haven't worked with Adobe Illustrator un awhile, so this info might not be
completely accurate. Illustrator seems to work best if the import files are
postscript, which you should be able to get from either acad or iv by setting
up a postscript printer that prints to a file, then import that into illustrator.
Hope that helps.
Bob S.
"stevensf" wrote in message news:16502343.1100524299478.JavaMail.jive@jiveforum2.autodesk.com...
> Can you import to Illustrator from IV or Acad and have a file that can be edited? Is there any special things ou need to do in
> Acad or IV before youimport into Illustrator?
> Fred
