Inventor Forum
idw to dwg 2d-shape
4 REPLIES 4
ehinson
509 Views, 4 Replies
idw to dwg 2d-shape
I hope somebody can help me. I have inventor 2013 and I try to convert a idw
drawing with 3 sheets to a dwg/dxf version for a supplier who has ACAD LT2012.
I tried to save as LT version, but he told me he just get a picture (bitmap
image). He asked me if I can export out to a 2d shape. What do I have to do?
Thanks for your help in advance.
ElkeCat Very Happy
4 REPLIES 4
Curtis_Waguespack
in reply to: ehinson
Hi ehinson,
You should be able to convert your file by going to Save As > Save Copy As > and choosing either AutoCAD DWG or DXF.
I hope this helps.
Curtis
blair
in reply to: Curtis_Waguespack
Also make sure you select Autocad 2012 or older. We use a couple of steel service centers and every once and a while I forget they are on older versions of Acad and I have to export to a older version of Acad than the default current year for them to open.
It always seems to happen on stuff that is a rush and behind before you start.
Delta Tau Chi ΔΤΧ
ehinson
in reply to: blair
Thank you for your help.
I exported to acad with options "file version AutoCAD2000/LT drawing and used Base View Scale - Model Space" and that worked. After that I had to open up the dwg drawing to exported it to R12 dxf.
Thanks again.
mrattray
I'd be wary of going that far back in time. That can cause issues, depending on how complex your drawing is. I recommend using 2000 format, myself.
Mike (not Matt) Rattray
