When using multiple sheets within an IDW. Can the first sheet start out with a number other than 1,
in otherwords start with sheet number 31, then every sheet after that be indexed by 1, ie 32, 33, 34 etc.
Solved by mcgyvr. Go to Solution.
Don't think so.. Wouldn't want it either.. Because then you'd be looking for sheet 30,29,etc..
But you can make a prompted text entry and have that become your sheet number instead. Then when you add a new sheet a dialog would pop up asking what the sheet number is.
