When I make a sketch in an idw file in Inventor 2014 I cannot modify the properties (ie line type, line weight and color) of the individual lines once I exit the sketch. I can modify them while in the sketch environment, but I cannot turn the visibility off on an individual line. I'm pretty sure I could modify properties of individual lines and turn visibility off when not in the sketch environment on previous releases. Is there some way to turn visibility off on individual sketch lines in 2014? Thanks. Phil
Solved by pquenzi. Go to Solution.
Solved by JDMather. Go to Solution.
As far as I know, you have never been able to manipulate sketch entities outside of the sketch editor. In the editor, you can set lines to be visible only in the sketch editor, is that what you need?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
ChrisB,
I could easily be wrong about editing outside of the sketch editor in previous releases. What I wanted is to have a line visible when in the sketch editor, but be able to turn its visibility off when the sketch editor is closed. It's not a big deal as I can work around it other ways. I just thought I could once do it. Thanks. Phil
Just to be sure - did you get this from previous response?
No I did not get that from the previous response and yes that is exactly what I wanted to do. I was not aware of the "sketch only" selection. Thank you. Phil
