Inventor General
Distinguished Contributor
Message 1 of 5 (129 Views)
Accepted Solution
idw sketches
129 Views, 4 Replies
02-06-2014 12:43 PM
When I make a sketch in an idw file in Inventor 2014 I cannot modify the properties (ie line type, line weight and color) of the individual lines once I exit the sketch. I can modify them while in the sketch environment, but I cannot turn the visibility off on an individual line.  I'm pretty sure I could modify properties of individual lines and turn visibility off when not in the sketch environment on previous releases. Is there some way to turn visibility off on individual sketch lines in 2014? Thanks. Phil
*Expert Elite*
cbenner
Message 2 of 5 (120 Views)
Re: idw sketches
02-06-2014 01:25 PM in reply to: pquenzi
As far as I know, you have never been able to manipulate sketch entities outside of the sketch editor.  In the editor, you can set lines to be visible only in the sketch editor, is that what you need?
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Message 3 of 5 (111 Views)
Re: idw sketches
02-06-2014 01:39 PM in reply to: cbenner
ChrisB,
I could easily be wrong about editing outside of the sketch editor in previous releases. What I wanted is to have a line visible when in the sketch editor, but be able to turn its visibility off when the sketch editor is closed. It's not a big deal as I can work around it other ways. I just thought I could once do it. Thanks. Phil
*Expert Elite*
Message 4 of 5 (109 Views)
Re: idw sketches
02-06-2014 01:43 PM in reply to: pquenzi
Just to be sure - did you get this from previous response?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Message 5 of 5 (94 Views)
Re: idw sketches
02-06-2014 01:54 PM in reply to: JDMather
No I did not get that from the previous response and yes that is exactly what I wanted to do. I was not aware of the "sketch only" selection. Thank you. Phil
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
