style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"reeds_93me" <We're
href="mailto:rstrickland@parker.com">rstrickland@parker.com> wrote in
message
href="news:f140604.-1@WebX.maYIadrTaRb">news:f140604.-1@WebX.maYIadrTaRb...
currently running IV w/ R6-SP2. Our company makes hydraulic cylinders, and we
like to show the welds at the main-to-endlug and the rod-to-rodlug locations,
as well as any port fittings that attach to the main. While IV was kind enough
to create weld features, they can't approach our groove contours. So, we fake
a lot of these weld seams in the drawing. Most every top level drawing shows
these welds in a view that is both sectioned (1/2 or 3/4) and usually broken
(to shorten the cylinder length to the sheet size).
I was recently taught
the neat trick of tying a sketch to a view (select view, then hit 'S' or the
sketch button) and until now had just been creating free-floating sketches and
'eye-balling' them to approximately the right location. My problem is that
with these view-dependant sketches, we'll create a weld seam and (paint) fill
it in to look like a cut weld. But if we save the file and get out, then come
back and we'll find the sketches have gone askew.
Typically, if we painted
a closed sketch made up from projected lines and sketched lines, the projected
lines are no longer present and we've lost the painted area (our sketched
lines are still present, just not the projected ones that close the area).
Additionally, we'll frequently have a curve that just blows up - it may not be
tied to any projected points, but it behaves as if one of the end points
stayed still and the other moved out to the un-broken length.
It is very
aggravating to have to re-edit these sketches everytime we re-open a drawing.
Is this a bug related to sketches on sectioned/broken views, or am I missing a
trick somewhere? I'll see if I can get a few pics and post them in the CF. But
for now, anyone have any insights? This problem is not all the time on all
drawings, and I'm starting to track the files where it keeps recurring in
order to find a trend or common trait. The files that have problems,
consistently have the same problem, and so far, most of the files have this
problem.
ps, sorry for the long post, I'm notorious for being long winded
when writing (and yes, I edited this down before posting it)
"reeds_93me" <
message
href="news:f140604.4@WebX.maYIadrTaRb">news:f140604.4@WebX.maYIadrTaRb...
*NOTE** I have added to the CF a pdf to show what I've got. I've given
detail views to help show what the idw looks like before (left) and after
(right) we add our welds to the assembly. In the top right details (E & J)
I've moved my 'free-floating' sketch away from the view, so you have an idea
of what's being done. For the top left (C & F), I utilized a view
dependant sketch to project the weld groove then added a top curve and filled
in the area to show the weld. For the two bottom welds, I again utilized view
dependent sketching on the lower left (B & H), and free-hand sketching on
the lower right (D & G).
1) What typically occurs is the projected
lines in C&F will not be projected when I re-open the file, hence I lose
my painted in weld. All I have is my little bubble curve on top.
2)
For E&J, not much happens, I just have to manually slide my free-hand
sketch to about the right place if I happen to have moved my view. No big
deal, just a slight aggravation and there is the fact that it's not totally
accurate.
3) for B&H, I project the vertical lines to anchor the
endpoints of my curve. That seems to be alright, but once I've finished the
curve and turn off visibility for the groove, I find that the groove lines
become visible each time I re-open the file. ARGH! I see it did it again
before I printed the pdf. You should only see two vertical lines and the curve
that bends below them - just as if you were looking at a weld seam in the real
world. Though it's odd, the vertical lines up the center, where the two
components meet, never gets turned back to visible when re-opening the file -
it's only the curves.
4) D&G are the real fun. I've used a view
dependent sketch, and didn't project anything. I just free-handed the weld
seam in place and made my groove lines invisible again. This is the situation
where the curves running vertically get blown up. Usually, the centerpoint and
one of the endpoints get moved way off to the right of the view (as if
reacting to the full length of the cylinder rather than the broken view
position). And do the groove lines become visible again? Sometimes yes, but
sometimes no.
And in answer to accu-cad, yes you have it correct.
The prefered/recommended method we are trying to use is to start an idw,
create our views, create a sketch dependent/tied-to a view, project what we
can and put the weld in place.
"reeds_93me" <
message
2)
accurate.
sometimes no.
"tbrack" <Forgot
href="mailto:tbrackbill@hamptonhydraulics.com">tbrackbill@hamptonhydraulics.com>
wrote in message
href="news:f140604.9@WebX.maYIadrTaRb">news:f140604.9@WebX.maYIadrTaRb...
to weld the retract port on! 🙂
I'm curious - how would you handle representing the same cylinder if the
retract port was rotated at say, 2 o'clock instead of 12 o'clock as shown? In
plain acad, we would draw it as shown and then call it out as 'Not True
Rotation'. I've struggled with this problem mightily in MDT where you can't
have a sectioned, broken view with one (or more) sections represented as
aligned. I fear this is true in IV as well. True, what we do sort of violates
real drafting rules, but our old cheatin' ways allow us to show both function
and construction details in a compact manner. If we go to IV, I fear our
drawings will have to get much larger and busier just accoplish the same thing
we did with dumb, 2D sticks (and hatches that behaved
themselves).
"reeds_93me" <Your
message
href="news:f140604.8@WebX.maYIadrTaRb">news:f140604.8@WebX.maYIadrTaRb...
file is fine. Though you are utilizing the weld feature, and we aren't - we
are just faking it in at the idw level. We haven't learned how to get the weld
feature to work properly with our J-Grooves. I'll check Dotson's and Bliss'
sites to see what more they can add to our use of the weld feature. For now
though, we are just sketching the welds on the idw and leaving the iam mated
but unwelded.
