Inventor Forum
idw revision table
19 REPLIES 19
Message 1 of 20
663 Views, 19 Replies
idw revision table
I change the template file to include a revision table with customized
columns but when I use the template for new drawings the settings are not
there (I don't want to each time reset the setings for the table). Am I
doing something wrong?
Vadim
2.5GHz P4 with 1GB
NVIDIA Quadro4 900 XGL
IV7 "basic"
Win 2000 Pro
19 REPLIES 19
Message 2 of 20
No, Vadim.
Revision table won't remember your settings. As designed. Another
half-baked feature.
Jon Genova
Senior Mechanical Design Engineer
BioServe Space Technologies
A NASA Commercial Space Center (CSC)
genovaj@stripe.colorado.edu
Bioserve URL http://www.colorado.edu/engineering/BioServe/
Personal URL http://stripe.Colorado.EDU/~genovaj/
Message 3 of 20
Thanks for the quick reply. I was afraid of that.
You mean IV has other half-baked features? 🙂
"Jon Genova" wrote in message
news:3F281FCB.716633B3@stripe.colorado.edu...
> No, Vadim.
> half-baked feature.
> Jon Genova
Message 4 of 20
I just use my own revision table made of sketched symbols. I think
many of us have stuck with this method- a carry over from pre-IV6
days.
I'll post mine in customer files.
Jon Genova
Message 5 of 20
Yes, it does stink.
Another workaround I have used:
Create the template as you want it. (As you already have it)
Make the Template Directory a Library search path (for easy access).
Now, when you want to create a new .idw, OPEN the template (since it is in a
Library Path, there is no fear of accidentally changing it)
Save copy as... to working directory with new name
Close template,
Open new file.
A few more steps for each file, but at least it saves all your sketch symbol and
rev. table settings.
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
news:3F282597.6CE37385@stripe.colorado.edu...
> days....
Message 6 of 20
No, they would never do that.
Message 7 of 20
Good idea. I'll try it.
-JG
Jon Genova
Message 8 of 20
Cumbersome work-around - but reflects creative thinking. 🙂
Maybe one of the VBA gods here can automate it so more of us can use this
technique? Kent, Sean, Charles?
"Dave Jacquemotte" wrote in message
news:B24640ACD2BF3721AACB57B366D93104@in.WebX.maYIadrTaRb...
> Yes, it does stink.
a
> Close template,
> Open new file.
symbol and
> Dave Jacquemotte
> Automation Designer
> www.autoconcorp.com
Message 9 of 20
Your wish is my command ..... Not really
This needs some cleaning up but ..... what do you want in 5 minutes and for free. 8^)
Obviously change the path to your path.
Public Sub NewDrawing()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "C:\AutoDesk\Inventor
7\Templates\Standard.idw", True)
Dim oFileDlg As FileDialog
Call ThisApplication.CreateFileDialog(oFileDlg)
oFileDlg.Filter = "Inventor Drawing File (*.idw)|*.idw|All Files (*.*)|*.*"
oFileDlg.DialogTitle = "New File Name"
oFileDlg.CancelError = True
On Error Resume Next
oFileDlg.ShowSave
oDoc.SaveAs oFileDlg.FileName, True
oDoc.Close True
Set oDoc = ThisApplication.Documents.Open(oFileDlg.FileName, True)
End Sub
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Ron Crain" wrote in message
news:181D17E5881C20A7AB3D141BE5AA0B75@in.WebX.maYIadrTaRb...
Message 10 of 20
You do realize, don't you, that what you posted makes absolutely no sense to
me whatsoever?
What is a common mortal supposed to do with those lines of text?
"Kent Keller" wrote in message
news:5D32A7EBFA0A8E8D59E16DCB62893CDC@in.WebX.maYIadrTaRb...
for free. 8^)
> oFileDlg.ShowSave
> oDoc.Close True
> End Sub
> Kent
> Assistant Moderator
Message 11 of 20
LOL
Open Inventor
Hit Alt F11
Double click on Module1 in the top left
In the right paste in all those lines of text
Edit the line that has the path to a IDW file to be the path to the template you want to
use.
Save
Go back to Inventor and run the macro. If you have MrMacro use it, otherwise Tools>>
Macros>> Macro.
You can make a toolbutton to run it, which Sean has outlined in his Tips and tricks I
believe.
Kent
Assistant Moderator
news:7BF594E1534F19BC596FA5533DECF779@in.WebX.maYIadrTaRb...
> me whatsoever?
Message 12 of 20
Is it really that easy?
And here I was impressed with VBA programmers LOL
Thanks - saved that one.
news:C68DEB435B3C41D6879BA8AFEB6371CE@in.WebX.maYIadrTaRb...
> LOL
> Open Inventor
> Hit Alt F11
Message 13 of 20
Kent may be due for a sainthood nomination for letting that one go by.
Hal Gwin
Mechanical Designer
Xenogen
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4351 drivers
Dell UltraSharp 19" LCD
Message 14 of 20
Kent, I ran your code once and it worked great. But I forgot I had changed the
paths here to a network path, so I closed all drawings, changed the code to the
correct path, closed IV all the way, restarted and tried again. When I did, I
got the attached error.
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
Message 15 of 20
NM, I added an "s" to the path where there wasn't one. Sorry. Thanks for the
quick code! Works a treat!
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
news:9A792337DFAD71BAD152B1878FB3628E@in.WebX.maYIadrTaRb...
the
> Dave Jacquemotte
> Automation Designer
> www.autoconcorp.com
Message 16 of 20
Perhaps I spoke to soon about it working. It creates a "New" drawing, without
symbols and rev. block, just like "New" command..
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
> Works a treat!
> Dave Jacquemotte
> Automation Designer
> www.autoconcorp.com
Message 17 of 20
See there you go Kent. Showing the mortals our powers are really just magic
tricks
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
news:6B48C6F6886E9DF69558D33DA097FDFF@in.WebX.maYIadrTaRb...
> > LOL
> > Open Inventor
> > Hit Alt F11
Message 18 of 20
What now you expect it to actually work??
I didn't have any symbols or rev blocks set up in my template so I
didn't notice. I will try to take a look and see what I did wrong or
why it isn't working right sometime today.
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
news:659F68DA991BC617E65064C11E2989BC@in.WebX.maYIadrTaRb...
without
Message 19 of 20
Ok finally got a chance to look at it. I thought this was probably what I had done. I
was opening the template file just like the program does when you do a file new.
Try this format for the line that has your template file in it.
Set oDoc = ThisApplication.Documents.Open("C:\AutoDesk\Inventor
7\Templates\TestStandard.idw", True)
Kent
Assistant Moderator
Message 20 of 20
YAY! Tanx, man.
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
news:4E122E42A2A8498C0BCAA8C79E98D917@in.WebX.maYIadrTaRb...
had done. I
new.
> Kent
> Assistant Moderator
without
